I'm using EK-KIT L360 (R2.0)
During the last week I noticed that the fluid level is decreasing slowly. Yesterday I flushed the system, took almost all of the liquid out. Rubbing the pump/reservoir combo with clean paper revealed that it is where it was leaking. Like leaking so slowly that it gets dried up, not causing any damage, but the paper got stained. So I removed the reservoir part, cleaned it up and then removed and re-seated the o-ring. I put the reservoir tube again and filled the system up.
Now the pump is clean on the outside but I noticed that the hole in the chassis of the pump top (above the inlet port) is slowly getting filled with liquid. The faster the pump works, the faster it fills up. Please check the attached picture.
How do I solve this? I don't want to be risking my system because the pump is leaking, it is positioned right above couple of hard drives.
Thanks in advance!
Thanks in advance!
