Ek Predator 240 + Water Block SLI?
ly-man
Hi there,
I finally think I'm ready to get another Gigabyte G1 980 ti for a SLI setup.
I know air is not the best solution for a SLI setup so I looked into the liquid cooling.
I saw a video where someone was using the Ek Predator 240 to liquid cool their asus 980ti poseidon.
Now my question is do you think the Ek Predator 240 would be able to cool 2 980 ti in SLI?
My Rig
i7 6700k > Nzxt Kraken X61 AOI
Asus Z170 Deluxe
Corsair Ven DD4 16gb
Gigabyte G1 980 ti (2x soon)
Corsair ax860i (upgrading to 1200i)
Thank you.
Hey Iy-man,
Noooo, the reason they could cool the poseidon was because it was 1 240mm radiator and the fans spin while it is in water cooling, so the temps are reduced further. You can Water cool 1x 980 TI windforce on a 240mm but definitely not 2, 360mm Might do it but it will be slim. I suggest 2x 240mm Radiators. Otherwise get 2x 980Tis poseidon, you can do it then but only with the poseidon line up because the fans on the GPU cool the liquid even farther.
Hey Iy-man,
