EK Slim 280 cooler questions
RonnieNiner
Commendable
Aug 30, 2016
7
Hey all!
So basically I have a few questions about watercooling.
For cooling both a fairly hot CPU (7700k OC'd) and GPU (1080Ti) what is the recommended radiator size?
I did some research and it looks like 360 is needed, however, my case can only fit 2x280.
So the questions are:
1. Can I hook up two radiators (say a 280 and 140) to a EK Slim 280 set? If so, can the pump handle both of them?
2. I want custom loops because of low noise ratios ( did research, and to be honest, they do have better performance/noise ratios than most air coolers to my surprise ), and the S240 has a relatively low noise, but the fans can only get as low as 50%. The S280 can do 500RPM, so they're basically more quiet, right?
3. Ultimately, do you think a 280 set would handle both components? If so, is it *worth* it? (Please note, that I'd add the GPU cooling part later on, I'm just curious, the CPU is my target)
Thank you!
Ronnie
