EK Water Blocks EK-DCP 4.0 X-RES mounting
adam_b123
5
Hello!
I have a EK Water Blocks EK-DCP 4.0 X-RES and need to install it in a Corsair 750D case.
Does anyone have any idea what the best way to do this would be? or has anyone used that combination before?
any advise would be appreciated :)
Looking at images online, it looks like that combo unit has a mounting bracket built into it. Its not going to line up with anything in the case, but its there.
One option is to get a drill, make some holes, buy some short bolts+nuts and use that to mount the unit to whatever surface you want really. The dead simplest option though would be to just put it on top of that removable drive cage, once everything is set the tubing wont let it move much.
I thnk thats going to be the best bet, the bracket it comes on seems to line up with the slot running down either side of the drive tray so I'll try bolting it onto there with some rubber or foam washers and see how it goes! :)
