EK Water Blocks Has Five 1080 Ti Water Blocks In The Pipeline
1. So newer people know for certain that it will work with their 1080 Ti.
2. So the wording 1080 Ti is on the block and not titan X.
Custom PCB's.. EVGA's FTW3 1080Ti is a custom board and the FE block wont fit properly.
Not a knock on water cooling, because I would love to go that route if it wasn't so expensive, but I think it's ridiculous that a $700 graphics card comes with cooling that is "sub-par".
If you want to avoid throttling, you'll need a AIB provided air cooling system or a water block. That's going to be true for the 1080 Ti just as it was for the 1080 / 1070. Water blocks for reference cards are interchangeable across brands and often between model numbers when two models use the same PCB.
