Hi, I'm currently running the 24 hour test of my newly installed custom cooling loopand have some questions, hope someone can help out (specs below).
Link to some photos: View: https://imgur.com/a/QnL3yH8
CPU AMD Ryzen 9 3950x
CPU Cooler EK-KIT X360 (radiator outside the case)
Motherboard Asus ROG Strix X570-E Gaming ATX AM4 Motherboard
Memory G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory
Storage Samsung SM951 512 GB M.2-2280 NVME Solid State Drive
Video Card Gigabyte GeForce GTX 1080 8 GB WINDFORCE OC 8G Video Card
Case Cougar PANZER EVO RGB ATX Full Tower Case
(Case fans: 3 intake fans at front, one exhaust at rear, all Cougar vortex 120 mm, plus two Noctua NF-A15 140 mm exhaust at top; 3* EK-Vardar F4-120 fans cooling the external radiator )
Power Supply
Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Monitor Acer Predator XB271HUA 27.0" 2560x1440 165 Hz Monitor
Keyboard Cougar DEATHFIRE EX Wired Gaming Keyboard With Optical Mouse
Thanks very much.
- the tubing running from the reservoir to the pump (sorry both photos are a little blurry) is sucking a little thin at the bend. Still good flow now. Should I be worried it's going to kink? (I'm planning to re-organise next drain - move the pump so it's blow the res and run straight down, but would rather wait to redo that.)
- the LED lead in the kit - is that just for testing a header?
- the pump runs fine from the molex cable for the test - is the cable to the motherboard header for monitoring the pump, or a 'belt and braces' second power supply?
Power Supply
Thanks very much.
