EKWB Working on 7 New Water Blocks
While some people would rather have a better air cooled card than a 750 under water, I can understand some people would use it.
Imagine a stock clock i5 and 750ti under water with a nice rad and silent fans crammed into a small case. Would be pretty cool.
As opposed to an overclocked i5 and 770 crammed into a just slightly larger case? 😛
I'm just saying, with an Apogee Drive II, a reservoir/rad combo and enough radspace, you can make a loop work pretty well in a crammed space like that, and higher end Nvidia cards really aren't so long as to be prohibitive anymore...
the only cases that would have space restraints that only a 750ti sized card would fill certainly wouldn't have room for a custom loop.
Your last point is the main thing. If you're going to spend hundreds on a custom loop system, why in the world would you stick with a 750 Ti? Not quite as elegant, but for $80 you can get an H50 and an NZXT G10 bracket and keep the GPU extremely cool, and use the $300 saved to get a 780 instead.
