EKWB's EK-Annihilator Isn't For You, But For Multi-CPU Workstations
It would be interesting to see this used with the X99E-ITX/ac in a super small case for the ultimate mobile LAN build.
You would be well advised not to move around a custom cooling loop machine all that much. People do of course, but you're flirting with disaster any time that you transport them without draining the cooling loop. One single connection working loose just slightly will quietly drain coolant directly into your extremely expensive electronics. It's just not a good idea.
If you want a mobile LAN build then just run a low profile CPU cooler at stock speed. If you don't overclock then a Coolermaster or Noctua low profile cooler will happily handle even high end chips and you can carry the case around with no problems. It's only overclocking and nerd epeen that makes water cooling desirable at all, and especially in a small form factor rig air will take up less space and be more reliable.
The block seems fine, but what really needs to be addressed is where your cooling is actually supposed to go. The reason we put up with the poor cooling of 1U racks is because they take up less vertical space; that's the trade off, but if you need more performance you put in several units; i.e- instead of one 3U system with dual or quad processors, you have three 1U systems each with dual processors but limited (or noisy) cooling.
I just don't see the appeal of using liquid cooling for this, as there's nowhere to put a radiator inside a 1U rack, which means going external, which means you've defeated the whole purpose of using a rack in the first place.
And really, what server setup needs to push an individual 1U system so hard that liquid cooling could make a difference?
It might be a different matter if we were talking about a bunch 1U systems, each with liquid cooling connections on the back, and all hooked up to some huge radiator system for the entire rack, but again, something like that would defeat one of the big advantages of rack systems which is ease of maintenance.
I'm just not sure what advantage this could possibly offer over simply putting your rack in a room with good air conditioning?
I agree wholeheartedly with your assessment. This water block is a great example of a solution in search of a problem. I half-expect EKWB's next product to be a water block for blade systems.
The only way I could see this making sense is if there were a 2U dedicated cooling product introduced as well that could provide cooling to the other 40 x 2-up systems in the rack. If EKWB could show that this combination allowed running with significantly higher ambient temperatures or minimal throttling, then maybe.
Otherwise I do not see the any ROI for sacrificing the warranty on 1U systems. One only tolerates 1U servers when space is the overriding priority and you are not using enough of them to warrant the overhead and cost of blades. Hanging a whack-a-doo cooling system off the rack isn't going to fly.
I disagree with LostAlone. I run a full CPU+GPU watercooling loop in my mITX box and I've moved it between 5 LANs (so far) and around my house depending on where I want to set it up.
If you have tubing disconnect that easily on a watercooling loop just by moving the case, then you're doing it wrong.
It's your risk to take and it's still a very real one. Sure, just moving your case shouldn't dislodge anything but shouldn't isn't the kind of word I like when I'm carrying around $2000 of hardware.
Just because nothing bad has happened to you (yet) doesn't make what you are doing safe or advisable.
Yet.
Maybe never, to you. But it happens, even to 'pro' built systems, even to closed loop coolers, and it's just irresponsible to pretend that it doesn't or can't.
Maybe you're really careful, maybe you're just lucky, but these are NOT systems designed to handle shock or impact, even minor ones and that isn't exactly outside the realm of possibility for transporting your case in the back seat or your car.
Maybe it's not that much of a risk as such but the worst thing anyone can do is pretend there is no risk. That's when you make bad decisions and see really horrible situations. When you're aware of risks and you go to the effort to protect against them (either by using other coolers, draining your loop or packing your case properly) then you'll never have a problem. But pretending there isn't a risk here is stupid, especially when handling equipment that costs more than the car you are transporting it in.
You wouldn't send you case through the mail with the loop filled would you? In a real sense that's what you're doing when you toss your case into the car. That's what the post office would do.
There's a difference between me shipping it and me handling it myself, and in fact, you run the risk of any PC being shipped ending up damaged...water or air cooled. If you want to argue semantics just to be right about something, sure, you can be right. Let me know how many watercooling rigs you've built and how many years you've been doing so.
I never said there wasn't a risk, but the risk is almost always vastly overblown by the uninformed forum poster that doesn't have experience in doing so. It's an assumption. If you don't secure tubing correctly with fittings, then you did something wrong to begin with and moving a case is only going to show that you did so, not being the cause.
Since you ask, I don't water cool.
Wanna know why?
Because In my late teens and early twenties I LANed every few weeks for about five years. In that time I saw two loops properly fail and write off expensive gaming rigs; the same both times - A guy pulling his rig out of the car and finding it leaking coolant out of the bottom.
I know that it's not a major risk, but exactly like I've been saying - That's not the point at all.
How many car accidents do you need to see before you put your seat belt on?
And how do you have the arrogance to argue against me telling people 'Be aware that loops can leak if you bump them around'. I get that you have experience working with watercooling more than I do, but where do you get off shouting me down for advising people to be careful with their super expensive, often irreplaceable technology?
You are mistaking the plaintext on this page as being a tone or arrogance simply because I differ in opinion than you do. I'm not at all speaking in that manner; I just have a vastly different opinion than you on the subject. Everyone has their own experiences - yours is seeing other people's rigs getting ruined. That's too bad, but they did something wrong, not simply that watercooling just leaks. The radiator hose on your car will fall off due to bumps on the road and leak coolant and warp the heads on your car due to overheating unless you secure it properly...same exact concept.
