EKWB's EK-Ascendacy Cooling Controller is Water Cooled
If the units is primarily PWM it is not like the VRM system will need much power since it will just run the controllers.
Now run that many 3 pin fans and it can need some cooling.
Either way, this is very cool. I hope other hardware makers follow this idea because some motherboard solutions are not always good.
Aquacomputer Aquaero is doing just that for years. There was bigNG, but it's nice to see a competitor at last. However, I'm worried about usefulness of EK's product: you can connect only one pump. Many run two pumps, some of them are PWM controlled (MCP35X), and 40W is not an issue, however, I run three Laings D5 in serial, and each one of them is rated for 36W - with current Ascendancy setup I could only dream about managing them.
