toddybody :
Very interested in a fully cooled loop.
Does EVERY card require a custom block? Or are there some standards regarding mounting holes, PCB height...etc.
The "reference" models will almost always use the same PCB and therefore the reference block will fit. But just as your system's performance will be limited by the weakest component with respect to that load, the card's performance will be limited by the cards weakest link. And with a reference card, that's likely to be the VRM. In short, adding water will not likely overcome the limitations of the cards power delivery and VRM.
Apples and watermelons. And no, it's not a good idea. This is a CLC type cooler on the hybrid.
1. Ever compare a CLC type water cooler with a comparably priced air cooler ? The CLC loses every time.
2. If you look at the performance of non-reference 970s, you will see that overclocked "bawlz to the wall", they don't come close to reaching their throttling point. As such, having a cooler GPU will never impact overclocking ability. You might sleep better at night knowing your GPU is at 55 instead of 75, but the only temp that affects anything is the 80C throttling point. Remember also, that on many 970s, they don't even bother turning on the fans until temps break 65C. So getting 55C accomplishes what ?
3. If the 970's performance is going to be limited by temperature, it's going to be limited by the temperature of the VRM. Hybrids generally don't provide water cooling for the VRM. Provide water cooling to the VRM, oft leave the VRM / memory with less cooling than the original air cooler.
4. EVGA doesn't do a very good job here of cooling the memory in the first place:
http://www.bit-tech.net/hardware/graphics/2014/09/19/nvidia-geforce-gtx-970-review/3
On the other side of the GPU is a metal contact plate that partially cools two of the four memory chips on this side, leaving the other two exposed. It also cools the MOSFETs of the power phases serving the memory, but no thermal pads are used, so heat transfer is likely to be limited.
5. Historically, even the pre-assembled EVGA full cover water blocks did an extremely poor job handling VRM and VRAM.
http://www.xtremerigs.net/2013/10/03/nvidia-gtx780titan-water-block-roundup/2/
VRAM temps on the Titan / 780 EVGA Hydrocoppers were 10C hotter than EKs.
VRM temps on the Titan / 780 EVGA Hydrocoppers were 30C hotter than EKs.
6. Your talking a world of difference between a 390x and 970 with regard to heat generation. Tho with both overclocked "bawtz to the wall", the 970 is significantly faster at 1080p and a hair faster at 1440p, they heat generation is very different. Your talking twice (1.93 times) as much. Your not going to handle 37o watts witha 1400mm radiator / fan combo and if ya tried the noise would be unaccebtable.
MSI 390x - 370 watts in gaming
http://www.techpowerup.com/reviews/MSI/R9_390X_Gaming/28.html
MSI 970 - 192 watts in gaming
https://www.techpowerup.com/reviews/MSI/GTX_970_Gaming/25.html
