Solution kanewolf May 19, 2016 First it is volts. I don't know what voltz are. Second wattage calculation, as said by @bignastyid requires volts and amps.
bignastyid Titan Moderator Jun 19, 2011 33,689 1,700 159,590 May 19, 2016 #2 Go to google.com and look up OHMs law and start reading. You are also going to need to know the amperage to find your answer. Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 38,654 3,818 156,790 May 19, 2016 Solution #3 First it is volts. I don't know what voltz are. Second wattage calculation, as said by @bignastyid requires volts and amps. Upvote 0 Downvote Solution
