Electric noise when plugging in power cable to PSU
Frinker
12
When I plug the cable in, it makes a couple of brief electric crackling (not sure of best word) noises. Anyone know what could be at fault here?
A warm plug (either end) may indicate some physical fault with the power cord: too much resistance or load, heats up....
Still your existing power cord may have some physical problem that interfers with making a solid electrical connection to the PSU prongs. And that end tends to be a bit tougher to physically plug in to begin with.
Then, if you are plugging it in while electrically live (i.e., plugged into the outlet) some arcing/sparking is taking place before the two ends are fully mated.
Plug in the PSU end first, make sure the plug is fully in place. Plug in the outlet end and see if the snappy sound stops.
If not, try another power cord and again plug in the PSU end first.
Yeah, it's like a snappy crackle sort of noise. The Power cable doesn't seem to be warm though. Also I was plugging it in the outlet first, I'll take a note of this.
