Electric Shock from USB Devices
cliffflip
64
Hi,
I just recently moved to another room in my house. In this room, I'm getting an electric shock from touching metal parts on my USB devices (especially keyboard & mouse). I even feel the shock when plugging in my headphone (ATH-M50, which has a metal jack) to my USB soundcard. This only happen if I place my foot on the floor without sandals or shoes, though. If I wear them, or place my foot on the desk (wood) or just lift it to my couch, I didn't feel it.
I've been reading on the Net for similar issues, and most of them feel the electricity from their metal PC case. It's strange because my case is also have a metal parts on the outer side but I don't feel anything from it, only from devices connected through USB ports. Not forget to mention that the electricity is even stronger when I touch any USB port directly.
It's like all threads I've read talking about grounding. Electricity isn't my strong suit so maybe I need some help here. I live in Indonesia, which using this kind of AC plug and socket http://en.wikipedia.org/wiki/File:Schuko_plug_and_socket_annotated.png. I've checked that every plug and socket has the earth clips. I've also read about the possibility of problem with grounding from the wall socket or maybe it's the faulty PSU. Is there any way to solve or at least determine what causing it?
If the air is very dry, you could be grounding yourself via the USB devices you touch. It's more likely that you have the large negative charge, and are discharging it into your devices. USB does include a ground wire (it's the metal sheathing on the connector), and it's grounded through the motherboard.
If not, it's possible that your wall outlet is not properly grounded, or that it's a faulty PSU cable.
Thanks for your reply.
I just found out I also feel the electric shock from my PS3, both USB ports and the silver part on the front (fat model), so I guess it comes from either the wall socket or the power extension I use. I'll replace the extension first and see how it goess
