Element 3D Unsupported GPU Problem?? [unrecoverable Error] Need a fix MSI GeForce GT 730
SiX Kay
Commendable
May 2, 2016
6
Here's my issue I never realized that Element 3D only supported specific GPU's seeing that I used it on my old GPU which is an ASUS GeForce 8400GS [JUST REALIZED ITS NOT SUPPORTED] But it worked perfectly NOW upgraded to a much better MSI GeForce GT 730 Which supports everything the 8400GS does plus what it does NOT support DX11/12 GL4.4 I mean 384 Cuda cores vs 16 Cuda cores!? WTF!? lol *rabble rabble.. I just made a cool project with my 8400GS and I only have one slot PCIE 2.0x16 I just bought this card yesterday its really good.
Is there anyway to get around this Element 3D error?? Im sure my GPU is very capable if the 8400 could handle it.
Setup: Athlon 64 X2 5200+ [OC'd @ 3.1Ghz]
AsRock A785GM-Le
Crucial DDR2 [2x2GB] 4GB Dual Channel
MSI GeForce GT 730 2GB GDDR5 OC'd Edition [1006mhz//5000mhz]
Custom Overclock [Core: 1303mhz/// Memory Clock: 6400 mhz]
Plz!! Help !!! If can thanks and if your gonna say just get a supported GPU understand I was intelligent enough to make it here lol with a stable OC on my shitty PC..
Update: Custom Added support for my GPU in RayTracer 3D for AE via RayTracerSupport txt file
then encountered the [RayTracer3D compile error] replace the optix.1.dll to fix the compile error
Assuming the application itself wouldnt support my GPU so therefore plugins would follow in changing that i still get the [unrecoverrable error] when I try to open Element 3D and the AE=25:3 error if try to open it again... HELP!!!
