Question Elevating bottom intake fans in the NZXT H6 Flow?
Apr 27, 2024
Hey everyone! Im new here but been lurking trying to find an answer to my question. No luck though so i'll ask;
Im doing a build in the NZXT H6 Flow. The bottom has a cutout fitting 2x140mm that mounts flush to the meshbottom.
My question is if elevating the fans 10-20mm with plastic risers or a plasticframe would negatively impact the airflow?
Thank you!
when flush;
cool air directly from the outside is being pulled in.
when lifted;
some inside air is being recycled through the fans.
why do you want to lift them away from the floor?
Yea I figured something like that might happen. Wonder how much of a difference it makes 🤔
The reason is I really like the Lian Li SL INF reverse blades and would be cool to see the entire fan.
Havent decided on which fans to use yet
