Do you have a multimeter/voltmeter?
It could be the power adapter is bad, could be the battery is bad, could be the motherboard is toast.
If you have a multimeter set it to 20v DC and take a paperclip or other slender metal item and put it inside the barrel plug end of your power supply (the part that you stick in the computer). Take your red lead and touch the wire, take the black lead of the multimeter and touch the outside metal part of the barel connector.
Check the voltage to what the bottom of the power supply says it is supposed to output. If it is more then 1volt less then that (or over) then the power supply is bad.
If not then try removing the battery and then plugging in the power adapter and see if that works.
Also if...
