Hello, I have 3 questions.. One is, Is the case for a W3609 a micro ATX? or just standard ATX.. Beacuse, If its Micro Atx, Im planning to put in this:
http://www.memoryexpress.com/Products/MX40624
and second question...
Since when you change out a Mobo, you need a new licence... Correct? Cant you just wipe thee one OS off the harddrive, and just reinstall it? beacuse the key can be used as many times, As long as there is no computer running the same key, Within a time period....
3rd question, Does the case support a ATX powersupply? or does it need a Micro atx?
Thanks for any answers for these questions
