The computer I normally do the posting with just went south....I hope not for long. I moved my computer into a very cold room with a fan and everything normally around 6-8 degrees cooler than I normally am in. So with the extra heat distribution i figured id mess around with my multiplyer and fsb. It was @ 10x 200 so i sitched it to 14x 166 but it only said i had 1Ghz so then I switched to 12x200....which I Have had it at before with no problem. However i booted it up and it said some problem with a file... hal.dll I think was part of it. I rebooted and now it just sits there at a black screen with a cursor blinking in the top left hand corner.....Help me please. Do i need to do something with some sort of jumper to redo my bios or something?
I have a 3 year old ASUS Deluxe A8N or something....I dont remember and all that info is stored on the afflicted computer.
Thanks you,
Rob~X
Thanks you,
Rob~X
