So my school sends a few students who do reasearch each year to the junior science and humanities symposium to do research and hopefully present it. I went a year ago and decided to work on something. I concluded that I would try to figure out a way to get a continuous endothermic reaction in a closed loop to cool computer hardware. Before I even try to find a way to reverse the reaction such as HVAC, I would like to know if it would damage the system somehow first. Im not asking for a reaction or a way to reverse it, just if it is simply safe.
I have decided (as much as I can) that amonium chloride or amonium nitrate reacting with water might be the best to use, as they yield at leat 15c cooling over plain water.
Would this corrode the blocks or tubing/radiators being used? Would there be any toxic by products? (note this would be a closed system as I would need all the products to be recombined into reactants which would create heat, hence the radiator.)
I could find a way to reverse it most likely, I just need to know if it would run in a loop.
