Enermax ETS-T40-VD Air CPU Cooler
AKGamer247
37
Hey Tom's Hardware Community,
I've been looking at buying a CPU cooler for my FX-8350 (which I plan to overclock) as I've read that the stock cooler is quite loud and generally not very good at keeping temperature low. Since my budget for the cooler was max £40, I decided that it would be best to stick with an air cooler.
I've explored many options, and in the end decided that the Enermax ETS-T40-VD is best. Is it?
It is apparently better than the Cooler Master Hyper 212 EVO.
Also, I understand that the Enermax ETS-T40-VD is quite large and so am wondering if it will be able to to fit onto an Asus Sabretooth 990fx GEN3.0 R2, on which I have 8gb of Corsair Vengeance CML8GX3M2A1600C9W RAM (2 sticks of 4gb) . Would the Enermax fit on the mobo? How many DDR3 slots would I potentially lose due to the cooler's size?
Would I encounter any problems with my choice of RAM and CPU cooler?
Enermax:
http://www.amazon.co.uk/Enermax-ETS-T40-VD-Vegas-CPU-K%C3%83%C2%BChler-Sockel/dp/B005DUHBRM/ref=cm_cr_pr_product_top#productDetails
Sabretooth 990fx GEN3.0 R2:
http://www.saverstore.com/product/20376056/7725665/SABERTOOTH-990FX-GEN3-R20-AM3?gclid=CMSgpsPU0LgCFfLItAodHScA-Q
Corsair CML8GX3M2A1600C9W RAM:
http://www.amazon.co.uk/Corsair-CML8GX3M2A1600C9W-Vengeance-Profile-Performance/dp/B005DKZK84/ref=sr_1_1?ie=UTF8&qid=1374601163&sr=8-1&keywords=Corsair+Vengeance+Low+Profile+White+8GB
Thank you in advance for all help!
All i know is XD (da goat man) says it's good.I'm inclined to take his word for it :)
A long time ago he linked me to some review results n stuff..It was better.
