Enough power for a 6850?
Andrewoi1
110
Hey. Just got a Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power Supply on a good deal. Was wondering if it would handle a 6850. My processor is intel i3 2100 and my hard drive is 500g seagate barracuda. If not would it run a 6770 fine? Thanks
Chaz21
1,022
You'll be ok as long as you're not going to CFX (for the 6770).
Will handle it without a problem.
Basic system with those specs won't put a 50% load on a 380w psu
http://www.tomshardware.com/reviews/diy-gaming-pc,2970.html
You should have no problems. That card consumes about 130W by itself at max load, and the CPU is rated 65W TDP but really consumes much less than that. Hard drives are not much to consider unless you have a lot of them; maybe 10W apiece when active. So you should have plenty of room.
Manufacturers always WAY overstate the power requirements to cover their own asses, because they have no idea what your build is, and for all they know you're an idiot who also has a space heater and two refrigerators hooked up to your system somehow.
Also, there's a pretty handy tool for overall system power consumption here:
http://extreme.outervision.com/PSUEngine
Your setup ran through at 241W after allowing for a few fans, two sticks of RAM, and a DVD drive in addition to what you listed. So pretty much in line with the results in the post above.
For a system using a single Radeon HD 6850 graphics card AMD specifies a minimum of a 500 Watt or greater power supply. The power supply should also have a combined +12 Volt continuous current rating of 26 Amps or greater and have at least one 6-pin PCI Express supplementary power connector.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Continuous Amperage Available on the +12V Rail(s) is the most important factor.
The Antec EarthWatts Green Series 430W (EA-430D Green), with its combined +12 Volt continuous current rating of 32 Amps and with one 6-pin PCI Express supplementary power connectors, is sufficient to power your system configuration with a single Radeon HD 6850.
