Enough power for my build?
Tayfun_1
Commendable
Dec 11, 2016
17
Hello, I was wonder if a GTX 1080 will fit in this build as in wattage. Is my power supply (FSP FSP500-60APN 500W 80+ Bronze) good enough to run this build a couple months until I get a new one? I am not planning to overclock until I'm gonna get a new power supply.
Specs:
Processor: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz, not overclocked stock speeds.
Memory: G.Skill TridentZ RGB 2x8gGb 3200Mhz CAS 16
Graphics Card: Gigabyte GeForce GTX 1080 G1 Windforce
Motherboard: Gigabyte Z270-x Ultra Gaming
Corsair H100i v2 AIO Liquid cooler
One Sata SSD
One Sata 7.2k HDD
2x case fans
91W TDP CPU, 180W TDP for the GPU does not necessitate a 750W PSU @Power94. Although the G2 are quality units.
I'd opt for a quality 550W unit OP.
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($55.98 @ Newegg)
Total: $55.98
Generated by PCPartPicker 2017-12-01 18:39 EST-0500
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($54.90 @ Newegg)
Total: $54.90
Generated by PCPartPicker 2017-12-01 18:40 EST-0500
It'll depend on your location though, as regional available/pricing can be a bit crazy.
my thinking is "better little more then little less" if he try to OC or something else he is better to be prepared for that scenario
Even heavily overclocked, you're not looking anywhere >400W. I mean, if the 750 G2 was a great price, there's no harm ..... but it's complete overkill.
https://tweakers.net/pricewatch/745439/corsair-cx550.html
https://tweakers.net/pricewatch/360227/seasonic-m12ii-evo-620w.html
https://tweakers.net/pricewatch/256222/seasonic-s12ii-bronze-520w.html
All quality options. The SeaSonic's are getting a little dated, but extremely high quality.
All within budget.
