[SOLVED] Enough power? R9 390x
Dec 23, 2020
22
So im looking to upgrade my gpu temporarily to an r9 390x and this means i need a new psu i was wandering if a 700w psu 80+ certified is enough for it or would i need more wattage like a 750w psu?
Aerocool cylon 700w semi modular 80+ bronze im not sure about age though
Edit: realised its not 80+ bronze its 80+ white.
A high quality 650-750 watt PSU is enough for a 390X, but the Aerocool model you have is terrible quality, made from cheap parts and has poor performance so I do not recommend using it with a 390x video card.
Dec 23, 2020
22
It depends on the rest of your parts, which you didn't list, and the quality of the model power supply you intend to use, which you also didn't list.
I have a xeon 1220 v3 cpu i have 1 ssd and 1 hdd i have 2 fans for cooling and 2x 4 1333mhz of ram ddr3 and im going to use this for gaming.
Dec 23, 2020
22
22
What about a Cooler Master MWE White 700 v2 Power Supply would that be good?
Edit: its a 700w psu if that wasn't obvious.
