Question Enough Power?
May 18, 2019
Will 600 Watts be enough power for my build?
Here's my build:
CAS: Syber M Series 2.0 ATX Mid-Tower Gaming Case w/ USB 3.0, & Side-Panel Window
CPU: AMD Ryzen 7 2700X 3.7GHz [4.3GHz Turbo] Eight-Core 20MB Cache 105W Processor [+30]
CS_FAN: 3X 120mm Color Case Cooling Fans for your selected case [+15] (Blue Color)
EVGA_POWER: EVGA PowerLink Revolutionized Cable Management Adaptor [+10] (Single Adaptor)
FAN: CyberPowerPC MasterLiquid Lite 120mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate (2x CyberPowerPC 120mm Dual Light Loop ARGB 1200RPM Fans w/ Hub + Remote (Push-Pull) [+16])
HDD: 120GB WD Green SSD + 1TB SATA III Hard Drive Combo (Combo Drive)
MEMORY: 16GB (8GBx2) RGB Lightning DDR4/3000MHz Memory (ADATA Spectrix D80 RGB Hybrid Liquid Heatsink Cooling)
MOTHERBOARD: MSI X470 GAMING PLUS AM4 ATX w/ RGB, USB 3.1, Gbt LAN, 3 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition)
POWERSUPPLY: 600 Watts - Thermaltake SMART series 600Watts 80 Plus Gold high-efficient Power Supply [+1]
PROMOSALE1: CyberPowerPC Elite M1 131 RGB 7-Color w/ 9 Button, adjustable Weight & lighting effects Gaming Mouse [+5]
PROMOSALE2: CYBERPOWERPC Skorpion K2 RGB Mechanical Gaming Keyboard [+5]
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: EVGA GeForce® GTX 1660 Ti XC Black GAMING 6GB GDDR6 (Turing) [VR Ready] [+19] (Single Card)
MONITOR: ACER XFA240 BMJDPR
Latest posts
