Enthoo Luxe fan layout
adambean
306
Hey all,
Planning a new build using water cooling for the first time.
I'm going with the evga 980 ti which has its own 120mm radiator. Then for the CPU, I'm ... not sure which to go with. Got a 5930k and unsure If I should do a single 120, 140, or a dual 240 or 280.
Looks are everything and I want this case to shine. I was thinking use the top for everything? 1x 120 for the GPU, and the 240 (or 280, does it matter?) for the CPU.
Then, replace the front 200m with dual 140mm blue led's and replace the back 140mm with another 140mm blue led.
Thoughts?
Thanks!
