Hi all, thank you for taking your time reading this.
I bought the Phanteks Enthoo Pro M Acrylic case and a Artic Freezer 240. The radiator is 38mm thick with 4 120mm push-pull fans.
I was wondering if you can mount two of the fans on the top of the top removable fan/radiator mounting bracket, then the radiator and lastly the other 2 fans.
That is probably not really a question as I removed the top panel of the case itself and tested regular <=25mm fans. They do fit, but tightly.
Can someone tell me if I will be OK doing it and or what they recommend? (I have not decided if it will be used as an intake or exhaust if I mount it this way.)
This will cool a FX 8320 (Asus M5A99FX Pro R2.0) alongside a GTX 970 G1.
I appreciate all the input from the community.
Ferdi
P.S. I can do the dual fan push pull in the front without any problems but I thought this way might be better airfrow wise and maybe looks... I will know when it is all done...
Ferdi
