If the intention is to move heat from the 'bottom' to the 'top' of the heat pipe like a vapor chamber, then it will be better to use a vapor chamber. The capillaries in a heat pipe will interfere with that action.
You assume the capillaries are directional, but they needn't be (and, in this case, probably aren't). See sintered capillaries, here:
Cheaper, mesh-type capillaries would probably also work reasonably well.
That's exactly my point. This is why it's bad design to put load across the entire heat pipe: It prevents "cold" parts from existing.
Some heat will leave the heat pipe at all points cooler than the vapor temperature. To that end, the heat pipe still serves to distribute heat into the fins. However, it seems implausible that an 8 W heat source is going to keep the entire heat pipe above the fluid's boiling point. Even without good air circulation, there'll be enough heat leaving the edges. It might even be the case that the fin block is really larger than it needs to be.
If the CPU saturates the heat sink at a higher temperature than the other chips -which seems likely, then putting other chips in contact with it will heat them up instead of cool them.
I explained this above, so I'll just remind you that the primary mechanism of energy transfer in a heat pipe is phase change. The majority of the heat leaves through condensation, which basically puts a ceiling on the temperature to which the CPU can heat the other chips - the fluid's boiling point.
I thought
your post was kind of rude - to speak so negatively (and at such length) about something, on the basis of such ignorance. I guess arrogance + ignorance != rudeness, but the effect is similar.
Depending on the resin holding it in there, it might not even be more effective than direct contact to the aluminum heat sink
That's the real question, IMO. How thermally-conductive is the resin, and does the heatpipe have much direct contact with the fins? If the heat pipe has a large contact area, due to being smashed against the aluminum, then I don't really care too much about the resin. On the other hand, if the contact area is small, then the resin could be a key weakness of the design.
Heat pipes cost a lot more than the copper that they are made of. All the extra steps to inlay it into the heatsink also adds cost that wouldn't be necessary with a solid copper heatsink.
It depends on how much you're talking about, but I'll drop this point as I don't have much current knowledge on the subject.
I just know that CPU heatsinks don't use copper fins. Moreover, the last such heatsink I saw that
did, had a significant price differential vs. a version of the same model that was mostly aluminum.
Edit: This video claims that a heatsink with integrated heat pipe is cheaper than equivalent copper heatsink without:
Of course, as it's
by a heatpipe manufacturer, it's certainly a self-serving claim.
