For some reason my computer will not start at all, the motherboard shows that it is getting power. Originally I noticed that it would not start at all when I pressed the power button on my case, so I checked the pwr sw pins to see if that was the problem and it still didnt boot. I tested my power suppy using the paper clip trick and when i plug in the 24 pin connector to my mobo with the paper clip attached the fans and my gpu start up but there is no display. I also tried using a screwdriver to start the system by placing it on the pwr switch pins but that does nothing. So the question is should I buy a new mobo, or is it my power supply?
Asus P8z77-v
Corsair Tx 750m
Asus P8z77-v
Corsair Tx 750m
