Entry Gaming Rig, HELP!
raysfan98
102
I have been looking to build a tight budget gaming rig for the past few months, to play games like Battlefield 4 and Minecraft. I want to play these games on high settings and was wondering if this build would be OK. (http://pcpartpicker.com/user/raysfan98/saved/xsP7YJ) I went with 4gb of ram and a dual core processor because Christmas is right around the corner and I can ask my parents for a core I5 and 4gb more of ram. I would have gone with an FX-6300 but the socket AM3+ is kind of dead, and I did not want a dead upgrade path. I feel as though this is a good starter build and a great way to get me into building computers and not only using them. All suggestions are welcome, Thanks. ^_^
It's a higher quality and it wasn't much more money. Still comfortably under your budget. It's normally around $60 so it's a great price.
In the end my max would be about $425, what is a good H97 MOBO you could recommend with front panel USB 3.0 headers? Also, do you think this build would perform just as well or better than the next gen consoles?
Here are the 2 changes I would make for a higher reliabilty
PCPartPicker part list: http://pcpartpicker.com/p/BfwTt6
Price breakdown by merchant: http://pcpartpicker.com/p/BfwTt6/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($97.27 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($67.98 @ Newegg)
Memory: Crucial Ballistix Sport 4GB (1 x 4GB) DDR3-1600 Memory ($37.96 @ OutletPC)
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card ($139.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($34.99 @ NCIX US)
Power Supply: Antec Neo Eco 620W 80+ Bronze Certified ATX Power Supply ($34.99 @ Newegg)
Total: $413.18
Generated by PCPartPicker 2014-11-24 01:50 EST-0500
