Question entry level pc
Sep 5, 2023
hi
i'm looking for a pc ,the main things i want it for is creality slicer, freecad and some arduino projects
at some point i would also like to try c++
have no idea what specs i need,any advice on what to buy would be appreciated
https://www.hpacademy.com/blog/freecad-system-requirements/
Recommended System Requirements​
  • Operating System: Windows 10, macOS 10.14 or later, or a Linux distribution
  • Processor: Multi-core processor with a clock speed of 2GHz or higher
  • RAM: 8GB or more
  • Graphics Card: Dedicated graphics card with OpenGL 4.0 support or higher
  • Hard Drive Space: SSD with at least 10GB of free disk space
This implies you might need a dedicated PCIe graphics card to support Open GL version 4. An inexpensive computer might rely on the Integrated GPU inside the CPU instead of a more expensive PCIe GPU. Check the spec of any machine you buy and make sure it supports OpenGL 4.0. 500 Euros might not be enough to buy a PCIe GPU.
