Question Envy 2019 low battery life?
connorh01
Commendable
Aug 20, 2017
130
I recieved my new HP envy 2019 - i5, 8gb ram, mx 250 gpu, touchscreen, 1080p model last night. I downloaded the programs I need for my uni work onto it, and despite reading reviews on the laptop being able to last 10+ hours, I only got a couple out of it. I charged it up whilst I went to work this morning thinking that it might need a full charge first and by the time I came to use it (at 100% battery) it only said it would last 3 and a half hours. Am i doing something wrong? Could someone help me please? Im not sure I have given all the details you may need but I can give more details upon request.
Nov 9, 2019
20
Check your windows power state, is it on high performance? If not then most likely has bad battery. I will search if it's a common problem and get back to you(I'm guessing you mean the envy 13?)
Ketchup79
Respectable
The non-touchscreen model will give you ~10 hours of battery life. The touchscreen model will give you around 4, but it all depends on what you are doing with it. Gaming will cut into that a lot, and the Nvidia graphics card won't get quite the battery life of the Intel stock graphics.
connorh01
Commendable
Aug 20, 2017
130
its on "Better battery" not on high preformance? not sure there is much of a difference tho?
connorh01
Commendable
Aug 20, 2017
130
I haven't gamed on it yet, although when I do I plan on plugging it in to charge. I basically only watched a bit of youtube and tried editing a video, and that made it go to around 3 hours on the full charge
Ketchup79
Respectable
