EP-4SGM8I sound problems
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
I've had lots of problems with this mobo (Built into machine when I
bought it) and although I've flashed bios a couple of times I've
always put it back as it was as it seemed to make things worse if
anything.
Anyway the main problem I'm having is with sound. even on low volumes
there's a fair bit of distortion and recording on my tv card sounds
awful. Is this a case of a driver needing updated or am I going to
have to buy a separate sound card or such? I don't use the 6 channel,
just 2 channel normal sound with a pair of old speakers which have
always sounded fine on other machines
All sound is rather like listening to a cheap radio
Paul (I got the horrors cos I'm one inch tall)
Stop and Look
http://www.geocities.com/dreamst8me/
"Paul Heslop" <paul.heslop@blueyonder.co.uk> wrote in message
news:41950B71.8225AED1@blueyonder.co.uk...
> anything.
Have you tried a pair of headphones instead of the speakers?
I presume that the Windows system sounds are poor too?
Graham W http://www.gcw.org.uk/ PGM-FI page updated, Graphics Tutorial
WIMBORNE http://www.wessex-astro-society.freeserve.co.uk/ Wessex
Dorset UK Astro Society's Web pages, Info, Meeting Dates, Sites & Maps
Change 'news' to 'sewn' in my Reply address to avoid my spam filter.
> > anything.
Sorry Graham, I should have made msyelf clearer (one of the many
problems I have) ALL sound is a mess. i use headphones plugged into
the speakers... did you mean just plug them into the socket alone?
Stop and Look
news:419537EC.E1008575@blueyonder.co.uk...
> > > anything.
volumes
channel,
Yes, the latter. There are several places that distortion can occur and
one of them is the powered speakers. So if you plug the head phones
into the computer and check the sound there you can eliminate the
speakers.
Usually bad sound is down to mismatched drive levels between
audio sections. Always run the speakers with their volume turned
fairly well up and set the computer Master Volume down to get the
right level from the speakers.
Put an audio CD in the CDRom drive and start it off. Turn the
edge-wheel to minimum and plug the speakers lead into the front
headphone jack on the front of the CDRom drive. Turn the edge
wheel up to get sufficient sound. How does that sound?
> > > > anything.
> volumes
> channel,
> speakers.
I tried plugging headphones into front panel on machine... VERY loud
and tiny but not a lot of distortion... then again, no bass either so
nothing to give it depth. I didn't try messing with it. The sockets on
the cd drives are hidden as it has one of thos fancy panels with
flaps.
The speakers are very sensitive, always have been, the volume has to
be quite low and they get loud very quickly. The one thing i did
notice is the sound will go off or unbalanced if I move anything
around inside the machine (inserting new drives or anything), and I
will have to remove the plug for the speakers and plug them back in
again.
Stop and Look
> anything.
Could be interference from the power supply or monitor. I've had both cause
sound problems just before failure.
> > anything.
Jees, this gets better and better. It's not a very old machine but I'm
reluctant to call up the makers as they'll drag it away for at least
ten days, then it'll probably come back worse than before.
Stop and Look
>>>>> I bought it) and although I've flashed bios a couple of times I've
>>>>> anything.
>>>>> volumes there's a fair bit of distortion and recording on my tv
>>>>> card sounds awful. Is this a case of a driver needing updated or
>>>>> am I going to have to buy a separate sound card or such? I don't
>>>>> use the 6 channel, just 2 channel normal sound with a pair of old
>>>>> speakers which have always sounded fine on other machines
>> and one of them is the powered speakers. So if you plug the head
>> phones
>> speakers.
> flaps.
That is what I was on about! It is possible that your speaker input
circuits are being overdriven by the computer.
So turn the 'Master Volume' down on the computer to reduce the drive
and turn up the volume control on the speakers to get a comfortable
listening level.
x"Paul Heslop" <paul.heslop@blueyonder.co.uk> wrote in message
news:4195C0CD.E771D8FE@blueyonder.co.uk...
<snipped for brevity>
> again.
Hmm...sounds like it's one of a couple of things:
1.) Be sure you have the plug for the speakers plugged *firmly* in the jack.
Quite often, some of these jacks are tight and when it seems like the
speakers are plugged in all the way, they're not.
2.) You have a poor connection which is either the speaker plug (gunk on the
plug itself or a broken wire inside the dialectric <insulation>), or more
likely, the pins on the inside of the jack aren't making good contact. If
that's the case, call the mfr. and strongly suggest they replace the
motherboard...or you can spend a couple of bucks and buy a sound card,
disabling the on-board sound in the BIOS.
hth.
Robert J. Salvi, Ambiance Acoustics
http://www.ambianceacoustics.com
San Diego, CA USA
(858) 485-7514
> listening level.
Well, I've been messing, I still hear a little distortion on bassy
notes and they're not as deep as I like but it's better
Stop and Look
> hth.
It has a minimum ten day turn around for the manufacturer, which is
why I'm reluctant... I asked them for a replacement fascia as their
delivery guy dented this one, twice I asked, twice I was assured it
was on its way... still waiting.
I think the jack itself is dodgy, I guess I should try plugging the
headphones into that socket and see what happens
Stop and Look
