G
Guest
Guest
I DO NOT intend to overclock...and how do I set the jumpers?
The manual for jumper settings isn't really clear
I'm using epox 8K7a+ with thunderbird 1.13 266mhz...
so should I change the JCLK1
CPU Clock Select which is 1-2(default) to 2-3?
what other jumpers do I need to set?
and also if I use the highpoint ide port for normal hdd use and didn't use it for raid...
if that is the case...do i still need to install HPT370A raid administrator?
