G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Hi
Yes i know its a blast from the past but my son has just bought it to use
while at uni.
He is using his laptop with Windows XP. The OS did not detect and install
the printer and kept giving error messages when trying to print. He went
through the usual driver, uninstall and reinstall routines but to no avail.
Somewhere along the line something got confused and now the printer wont do
anything and is flashing the lights on the control panel. The handbook says
contact your dealer if this happens but of course with an old model printer
that's not an option.
Can anyone advise a course of action (not chuck it in a skip, that has
crossed my mind) is it possible some irreversible damage has been done or
can it be reset.
thanks in advance
Gary
vist our website at www.justjents.co.uk
Hi
while at uni.
can it be reset.
thanks in advance
Gary
