Epson R200 - red diodes flashing problem
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Hello,
the other day I replaced all 6 ink cartridges by new ones. Ink jet pattern check and
counters (full) were OK.
Today, when I tried to print a page the two red error diodes came on flashing
synchroniously.
Paper feeding is OK. CD-printing device closed and OK. No paper obstructing the
printing head travel .
Turning the printer off and on results in the usual ink wasting initializing procedure
and comes again to a hold with the two red diodes flashing and the green diode going
dark.
Any idea what could make the printer behave like this?
Herb Henkler
Is this another case with 3rd party ink?
H.Henkler wrote:
>Hello,
>synchroniously.
>dark.
>Herb Henkler
The paper and ink LEDs can blink in three different manners:
Alternate blinking between them
Paper LED blinking with the Ink LED blinking faster
Both Paper and Ink LED blinking fast
From your description, I am assuming you are dealing with the first.
This indicates the waste pad is considered full of ink and requires
replacement. If the printer is under warranty, send it back to Epson.
If not, you need to bring it to a warranty/service depot and pay to have
the waste ink pads replaced and the software reset.
Art
H.Henkler wrote:
> Hello,
> synchroniously.
> dark.
> Herb Henkler
> have the waste ink pads replaced and the software reset.
Why can't most people do that themselves?
> Art
> H.Henkler wrote:
>> Hello,
>> pattern check and
>> flashing
>> synchroniously.
>> obstructing the
>> green diode going
>> dark.
>> Herb Henkler
In article <G_f4e.1385$qD2.1144@newssvr14.news.prodigy.com>,
measekite@yahoo.com says...
Mostly because Epson no longer allows you to own the software that re-sets
the printer to a "empty waste" condition.
In the past (about when the Epson Stylus 600 series came out) you could
download it, but not anymore.
Larry Lynch
Mystic, Ct.
"measekite" <measekite@yahoo.com> wrote in message
news:G_f4e.1385$qD2.1144@newssvr14.news.prodigy.com...
>> replacement. If the printer is under warranty, send it back to Epson. If
>> not, you need to bring it to a warranty/service depot and pay to have the
Because Epson - in their ultimate wisdom - made it as hard as they possibly
could to firstly get to the waste ink pads, secondly not making replacements
available and thirdly not giving users any way of resetting the waste ink
counter.
If you want to do it yourself its certainly possible though. Good luck with
trying to get into the printer without damaging the casing - poking it in
the right places will get the covers and all the mechanism that's in the way
of the waste pads off. You can then remove them, wash them out and dry them
for a few days before refitting, and then hope you can get the printer back
together in one piece without messing up the alignment too much.
SSC from http://www.ssclg.com/epsone.shtml says it can reset the R200's
waste ink counter, but I've not tried it so you might also screw up your
eeprom settings as side effect.
Take note of the interesting caution in the R200's service manual though:
{quote]
For the existing Low End models, it is basically forbidden to remove
"Housing, Lower" from "Printer Mechanism". This is because the strength of
"Frame, Main" is not strong enough, therefore, "Frame, Main" may be
transformed when removing/ reinstalling it from/to "Housing, Lower". For
that reason, when replacing "Ink System" or "PF Motor", it is recommended to
replace not only "Housing, Lower" but also "Printer Mechanism".
For this printer, it is necessary that "Housing, Lower" be removed from
"Printer Mechanism" when replacing "Waste ink Pads" or "Ink System Unit".
Therefore, this chapter specifies the disassembly/assembly of "Printer
Mechanism" which "Housing, Lower" has been taken out in order to secure the
quality of the repaired items.
[/quote]
In article <uhg4e.7268$il.1409@newsfe5-win.ntli.net>, Ivor@somewhere.uk
says...
The SSC utility worked fine for me without screwing anything up.
On a Canon (through the i960 anyway) it can be done with a give sequence of
"button presses" on the printer, though I dont remember what the presses are
off the top of my head.
Larry Lynch
Mystic, Ct.
> Art
Hello, Art,
both red LEDs were blinking FAST and SYNCHRONOUSLY. Since the printer is 2 months old
(new) only and I have consumed only one set of cartridges so far the ink pad (counter
resp.) cannot be full. The third party cartridges I have installed are from Pelikan
(Germany), a supplier with a good reputation. Pelikan gives a compatibility warranty for
their cartridges.
So I took the Epson R200 printer to the dealer today. They checked the printer and will
have it fixed under warranty.
But I still wonder was is going on ???!
Herb
I was told this person is actually dealing with the 3rd situation, so he
is getting it replaced under warranty (the third condition means a
problem with the head carriage or paper feed motor)
But, to answer your question, the reason people can't replace the waste
ink pads themselves is because:
The pads are usually under the whole printer mechanism, requiring a
major dismantling
The EEPROM reset requires propriety software to reset it
Some of these ink pads are cut specially to fit correctly
And why is it done that way rather than either using a waste ink bottle
or a tray that comes out and you just put in a new pad? IMHO it's so
Epson service stations can make money on it, or people will toss the
printer because the cost to do this repair is often close to half the
price of the printer.
IMHO it's just a scam.
Art
>> Art
>> H.Henkler wrote:
>>> Hello,
>>> pattern check and
>>> flashing
>>> synchroniously.
>>> obstructing the
>>> green diode going
>>> dark.
>>> Herb Henkler
Just a slight correction. Until quite recently, there wasn't really
anything to download, in terms of resetting the waste ink pad
"protection numbers". It was just a matter of holding down the right
sequence of front panel switches and buttons.
Recent printers from Epson now require a software program to reset the
firmware for this purpose, and that isn't readily available to others
than official service depots.
It is a dirty trick IMHO, and might even not be legal.
Art
In article <L5u4e.528$VF5.266@edtnps89>, artistic@telus.net says...
> Art
I probably miss-remembered, there was a LONG period where I wasnt buying
anything Epson.
I do know that the SSC utility works for re-setting the waste ink numbers if
you use it before the printer gets to the maximum and locks up.
I dont know if it will work after the lock-up though.
Larry Lynch
Mystic, Ct.
I've responded in private email, and in another earlier posting with the
same subject heading.
Art
> Herb
news:uIz4e.9569$FN4.837@newssvr21.news.prodigy.com...
> >So, for about the cost of shipping the printer somewhere for service, you can
> >load your closet with ready-to-go replacements that need no shipping or labor
> >charges. Is this not a no-brainer?
> Why stockup, the replacement for them with improved technology will most
> likely be the same price.
because the stock-up price is about $20 each. The new price will likely never
be that low.
[uh, the no-brainer part of the cost equation?]
