Hi all,
I am going to buy a new printer and I was suggested to choose the Epson WF-5620DWF as a suitable alternative to a laser color multifunction printer.
I strongly need something that can perfectly work even after 2/3 months turned off. This is why at first I had considered a laser printer. However, this Workforce appears to be much more economical (in maintenance) with comparable features (and of course a better photo quality, as it is an inkjet). Furthermore, I was told that it uses a new technology which should avoid the clogging problem.
But... to your knowledge, is it true?
Is it possible that an inkjet like that stays unused and turned off for 3 months and then instantly works without asking for any cleaning procedure?
Also: as cartridges are supposed to last for over 2000 pages, I am likely to use the same cartridge for over one or two years. Will it dry in the meantime?
