Hi! I had just installed XP on my system and after installing some software from my external hard drive i realized that something went wrong with the install so i decided to reinstall the os. I forgot to switch off my external hard drive and when windows loaded all the files and asked me where did i wanted to install xp and all that, both drives appeared, my internal hd and the external with all my data. I was doing something else at the same time and i wasn't paying all the attention i should have so i deleted the partition of my usb Hd and just after i did it i realized my mistake and in a moment of desperation I removed de usb cable and turned off the ext hd. The file system for that drive is ntfs and there was only one partition. I did not formatted the ext drive, i only deleted the partition.
I need to recover those files, they are irreplaceable and really important.. If anyone has a solution it will be gladly appreciated.
