ERR_CONNECTION_RESET on vimeo
samborambo56
163
Certain parts of the website vimeo.com are giving me the error message in the title when I try and go to them. However, This does not happen in incognito mode (I'm using chrome)
Also, I sometimes randomly get that message on other sites then I just refresh and it works. :s
Anyone got any ideas? 🙁
Have you tried updating your connectivity drivers? i.e LAN or wireless adapter? Have you ruled out that the same site on similar machine with the same OS is running fine? If so then the issue is solely confined to your browser on this particular machine. Did the issue crop up after a mandatory windows update? If so then you could try a system restore to a point prior to being aware of the issue. You may also try a repair install to ward your unit of any corruption in your OS installation.
Speaking of installation, is this installation availed via the free upgrade path or anew? Can you also please pass on your full systems specs?
Latest posts
