Erratic Frame Rate Issues
iitzstevo
8
I have a Radeon HD 7850 2GB. I have some small issues with other games, but the biggest offender is Diablo 3. At its worst, my FPS will hit 5 even with nothing heavy on the screen. At best, I get too much stuttering and microstuttering to be considered normal.
Weird thing is, alt-tabbing and re-opening seems to sort of "reset" my FPS, until it eventually drops again. I notice the it happens the most upon entering a new area. i.e. I open Diablo, rush into an area, and my FPS just hits the floor.
I don't see a way to post my DxDiag or MSInfo (Blizzard customer support wanted to see this), but if anyone wants more info I would be more than happy to give you whatever info you need to make a creative guess. I am sick of this...
Try it.
It might be the best solution for you, and games might not lag anymore.
Also if you cant try softpedia for some older drivers.
iitzstevo
8
I have done a clean reinstall of drivers 3 times now. Even down to deleting old hidden AMD files, cleaning up registries, everything.
Should I do it again?
Bassim Ansari
531
Using Driver Sweeper ?
It's no good uninstalling and installing by self.
If you've done all that, you might want to re install drivers that are a bit older than the newer ones.
You can find most old drivers at filehippo
iitzstevo
8
I used the AMD Catalyst uninstaller then I manually did the rest using a nice tutorial.
How far back should I go with the drivers?
iitzstevo
8
All of their drivers are for Vista or XP. I found a page for it on AMD's website but it was all Linux... I'm using Windows 7. I can't find the disc that came with my GPU.
Bassim Ansari
531
Try it.
