Erratic GPU usage causing low frame rates.
Dashe101
9
FX 8350 4.0 ghz
Sapphire HD 7970 GHZ Vapor x
Corsair Vengeance 8 gb RAM
Corsair CX 750w PSU
Sabre tooth 990 FX r.2 mobo
H100i CPU cooler.
Playing at 1920/1080 res.
For the past couple months I have observed low frame rates in all games, be it BF3 to TF2. I think I have found the reason for the problem but not the solution. For example when playing BF3, when
my GPU usage is 80-95% used, I get frame rates in the 90's and 100's. Although when I turn my character to where the action is(explosions, other players, vehicles) my GPU usage drops to about 50-70% and my frame rate plummets to about 30.My CPU usage stays at a steady 50-60% all of the time though. I don't know what is causing this but the same goes for all other games. I don't think a CPU bottleneck is the cause and my temperatures are normal across the board. Does anyone know what could be solving these problems?
cpu bottleneck...
if the gpu isnt hitting like 98-100% on the 'smooth' parts then the cpu is already holding it back, looking at explosions and stuff adds even more stuff for the cpu to calculate and the gpu load drops further...
Is it normal for an FX 8350 to bottleneck a 7970 GHZ?
Have you seen an FX 8350 bottleneck a 7970 ghz in all games though? Is this normal?
