error 0xc000007b while running pes 15
Karan Yadav
40
guy's today i installed pes 15 on my pc and it installed flawlessly but when i tried to play it showed error code 0xc000007b i googled and downloaded many dll's ran aio 210 somehow i came to know about dependency walker it showed some lost dll's which i placed in system 32 and syswow 64 then also the game would'nt run dep. walk. showed error's as follows
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Error: Modules with different CPU types were found.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
so helppppp me as i'am dying to play it
thanks in advance
install the latest direct x and .net frameworks. from the games redistrobutable folder on the disk or file folder (may be called something different like resources or data)
run sfc /scannow from the cmd prompt
run ate game with admin privs.
that aio fix on youtube is junk. it installs 32bit dlls on a 64bit o.s without checking to see if there the needed/compatible versions.
directx 11 already installed
.net frame work 4.5 already installed
you can have dx11 installed but it may still need updating so run the dx web installer again.
also make sure you download the june 2010 dx10 package. it has libraries that dx11 doesnt have that some dx10 games need.
run a game as admin . just right click on the game icon and select run as admin from the drop down menu.
if this works make it permanent by checking the check box in the compatibility settings in the game icons properties.
you're great bro, i ran sfc as you told and got the results as belows
2015-02-05 01:35:41, Info CSI 000002ee [SR] Beginning Verify and Repair transaction
2015-02-05 01:35:42, Info CSI 000002f0 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-02-05 01:35:51, Info CSI 000002f2 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-02-05 01:35:51, Info CSI 000002f3 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2015-02-05 01:35:51, Info CSI 000002f6 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2015-02-05 01:37:32, Info CSI 00000340 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-02-05 01:37:32, Info CSI 00000342 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-02-05 01:37:32, Info CSI 00000343 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2015-02-05 01:37:32, Info CSI 00000346 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
2015-02-05 01:37:32, Info CSI 00000348 [SR] Repair complete
so now how can i manually correct these errors now
try running scf /scannow in safe mode.
ok i will do this
remove each file manually, then clean the registry then run sfc /scannow after you reboot
how will i know the path of the corrupted file and can i use ccleaner to clear regitry
so u want to say that when i delete those corrupted files windows will automatically place new files in place of those and i need not do anything
and also there many iassdo.dll.mui listed so i have to hunt for many of them or just killing one file will do the job
if there basic windows files. but honestly i dodnt know any legit games that place files in the windows folders.
generally games will just put the dll's it needs in a data folder within the games install folder so im a bit baffled as to why yours didnt.
so what to do now
