Error 105, dns problems
Rokas2260
154
Hi... I been trying to fix this problem for hours by googling every way I can find, basically I can't access any page on internet because I get www.google.com's server DNS could not be found. And things I have tried: opening cmd (admn) commands like, ipconfig/flushdns (release, renew. Also with NETSH winsock catalog commands) I tried changing dns server address with 208.67.222.222 or 208.67.220.220 or 8.8.4.4 or 8.8.8.8 and still nothing... Many restarts, and unplugging the cable, turning off and on modem, still nothing... Also cleaning all cookies, and deleting files from C:\windows\System32\drivers\etc\ after all of those I also tried going in chrome://net-internals/dns# it shows on every address (error:-105 (ERR_NAME_NOT_RESOLVED)) so yea.. I'm out of ideas... I'm using windows 10 pro..
What happens if you go to the cmd line and use the NSLOOKUP command. You can try multiple DNS servers. If it works from the cmd line then it is only a browser issue. If it does not work from the command line something is blocking your DNS. You need to try a different device to be sure it is not your router or ISP with some strange issue.
I tried that command and this what it showed me:
Default Server: UnKnown
Address: 2a00:c1a0:0:800:217:68:161:141
My steam seems to be working, skype is acting strange though.. It's like showing differently contacts and does not let me call them because it just shows connecting...
Anyway this thread can be closed, after I did a lot of troubleshooting... After all of that, basically malwarebytes when was upgraded to free trial, it screwed up everything... When I deleted it, everything came back to normal.. So thanks for help anyway
