I just replaced the previous 120mm case fan with a new 200mm fan. But every time i start the pc, it cant boot cause the error in the title. I must push f1 in the bios to let windows booting.
The fan works fine, is correctly plugged and is detected in the bios monitoring section, also in windows.
It has 3 pin connector and mobo has only that one 3 pin connector for case fans.
The mobo is an orrible mobo from a HP oem pc. This pc came with a little case fan, but recently i replaced the case with one bigger. And also changed the fan with the 120mm one i previously mentioned. In this case i have not encountered the 512 error.
I dont know why that occurs now.
Thank u all for the help
