ERROR: beeps with red led BOOT_DEVICE_LED
Aug 17, 2018
It beeps for what seems like one long and three short and it repeats
A red led occurs on the motherboard BOOT_DEVICE_LED
It does not boot up to bios or anything it just starts and you hear the beeps then continues running with no display or anything.
It was working perfectly fine last night. First time running into this error.
What MB do you have? I will see if I can find a beep code chart for it. Or just look in the manual if you have it. Those kind of things are usually listed in the Troubleshooting section in the back of it. If you don't have the paper manual just do a Google search with your MB brand/model followed by pdf manual. The manufacturer's site would also have it under Support on it's product page.
Aug 17, 2018
I have a sabertooth x79 and according to the beep code it has to do with no vga detected but ive never used one with it and it has worked
Aug 17, 2018
