The motherboard manual mb_manual_ga-z170x-ud5_e.pdf shows the SYS_FAN connectors on page 26. The pins for SYS_FAN are listed as:
1 GND
2 Speed Control
3 Sense
4 VCC
I have 3 pin case fans. With GND and VCC on the outer pins, there is no possibility of plugging in 3 pin case fans to contact GND and VCC.
Also every reference I find for 4 pin fan pinouts is different than shown in this manual. See http://www.pavouk.org/hw/fan/en_fan4wire.html
http://www.allpinouts.org/index.php/Motherboard_(CPU)_4_Pin_Fan
Also it seems unusual to have the SYS_FAN connector specify VCC instead of +12V. VCC normally refers to +5V.
Are the 4 pin fan pinouts in the manual correct? If they are correct, how are 3 pin case fans connected?
1 GND
2 Speed Control
3 Sense
4 VCC
