Question Error_code: 0xc000000d and Stop code: DPC_WATCHDOG_VIOLATION ?
Dec 31, 2023
5
Hello all I'm currently stumped at what is wrong with my pc. I've tried SFC scan and trying to repair my boot drive/windows 10 file and it still is running into errors on bootup. The 2 blue screen errors I run into are Recovery Your PC Couldn't Start Properly A required device isn't connected or be accessed error_code: 0xc000000d and Stop code: DPC_WATCHDOG_VIOLATION. It's odd because maybe out of like 6 attempts to boot up, 1 will go through successfully and start up properly. I've also tried doing a windows 10 re-install via USB. It will get to the 3rd page of where I activate a key and freeze.
My current specs are
Processor : AMD Ryzen 3950X
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard
SSD (used for boot drive): Samsung 970 Evo 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
Graphics Card: NVIDIA Founders Edition GeForce RTX 3080 10GB 10 GB Video Card
HDD: Seagate Barracuda Compute 2 TB 3.5" 7200 RPM Internal Hard Drive
Any help is greatly appreciated, TIA
The 0xC000000D exception code indicates that an invalid parameter was passed to a function. The DPC_WATCHDOG_VIOLATION bugcheck indicates that a DPC (the back-end of device interrupt processing) ran for too long.
The conclusion must be that a boot loaded driver is misbehaving and causing both these issues. First try starting Windows in Safe Mode - that's a stripped down system with only critical services and no third party drivers loaded. If it boots consistently into Safe Mode then that would confirm a rogue boot-loaded driver.
If it boots in Safe Mode then next try a Clean Boot of Windows. This loads a complete Windows system but you can select which third-party drivers are loaded at boot time. Start with no third-party drivers and if that boots reliably then use a binary sort technique to add in third-party drivers until you find the culprit. Bear in mid that there may be more than one.
Thanks for the reply, I tried getting into Windows in Safe Mode but ultimately it just ended up blue screening again with error code 0xc000000d and it saying Your PC/Device needs to be repaired A required device isn't connected or can't be accessed.
Can you boot the Windows installation media?
So I recently tried isolating the problem (i disconnected all other ssd/hdd from the pc and had the bare minimum mouse and keyboard only plugged in) but ultimately it still freezes when trying to boot from the USB. I also tried swapping my boot ssd with a new one to see if its just an issue with the ssd but it still also freezes with the ssd.
That doesn't sound good. Try removing all drives and see whether the Windows install USB will boot.
just attempted to boot via the USB with no ssd/hdds attached but it still froze. its starting to make me think it might be a hardware issue rather than a software issue
Oh, it's most definitely a hardware issue. There is NO doubt about that. The question is what hardware....
gave up unfortunately and caved in to going to a pc repair store. They said they have isolated it down to the CPU or Motherboard. I wonder what the issue lies after finding which hardware part is the problem.
