Hi, I would like to know if this will work.
The idea is using this eSATA port,
with,
to connect usual internal dvd-rw optical drive.
My guess it should work, although Im not sure if eSATA port will be able to power optical drive without a problem.
So my question is, will this safely work, in the same manner as if I used normal SATA connector with a PSU connector for power?
Thankyou
with,
Thankyou
