ESC installation problem
Geoffroy
Hi
I have problem to install a motherboard from ESC. It is model 761GX-M754. I have install this motherboard in a case and I have added memory. When I start the power supply the cpu fan begin running but never appear on the screen. I have made test with two differents memories, two different cases and two differents motherboad ( I have two copies of the same board). There are no lot of jumper to set on this board. All the time I have used the default configuration.
No but I'm sure the monitor is ok. The only thing I'm not sure is the memory
Curious why you think it's the memory given you said you tested it with different RAM. Other things you could try: Clear the CMOS, test the monitor on another machine, try a video card, try a different hdd (not likely the problem but worth a try) and make sure the monitor is turned on. The last is not to be insulting because I actually ran into this one time when I had the same problem. Tore everything a apart only to discover the monitor was turned off 😳 If the board is still under warranty, RMA it.
