Ethernet and PCI simple communications controller drivers not installed
meow91006
I got the cable connected yet my PC doesn't detect it. I went to the computer management part and under other devices, I found Ethernet controller, PCI simple communications controller and USB controller in yellow exclamation stating drivers not installed.
I clicked update driver but it still asked to search over the internet. What should I do?
Acer Aspire v3-471g
Window 7
32 bit
Normaly you would go to acers support site for your exact model# and download the drivers. Can you tell us the full model# from the sticker on the bottom?
Hey, thanks for suggesting. Yes, I already visited their website and downloaded the driver (probably the one I needed). After installing it, it did detect the LAN (problem fixed, I thought). I still went to the "computer management" section and PCI simple communications controller and USB controller were still in yellow exclamation.
Well, at least, I guess, I have my LAN connected which is my only concern for now.
Thanks any way. 😉
