Hello!
I've had this anomaly where whenever I boot my PC up (no error messages or anything off/fishy pop up) and for a few minutes my computer does not recognize my plugged in ethernet cable. First of all, because it's a desktop PC, the ethernet cable is plugged in at all times, never removed. The computer is fairly new (as I had built it myself last year-ish).
The strangest part is that it doesn't happen every time, it happens at random intervals. As I do have multiple PCs in my household, I've confirmed that the ethernet cable is OK, as this problem does not occur on other PC's with the same ethernet cable. I've started to think that my motherboard is faulty.
What I saw today was something totally new. When I booted up, I quickly went to the Network and Sharing Center and my main Ethernet device kept blinking between the red circle with an X in it (no ethernet plugged in) and the Yellow exclamation mark (the blinking interval was somewhere between 5 seconds and lasted for ~2 minutes until it finally recognized the ethernet cable). I've laid my eyes on the I/O of the motherboard, focusing on the ethernet port and nothing seems off. Everything looks like it's supposed to look.
Could the problem have something to do with faulty drivers? I'm out of options at this point.
As for my computer specs:
Mobo: Asrock 970M Pro 3
CPU: AMD FX 8320
GPU: GTX 970
RAM: 2x4Gb
128gb SSD for boot files and a 300gb HDD
OS: Windows 10
The cable itself should be a standard issue CAT5, been using it for years without a single problem. The router I use is by Cisco (can't remember the model) but I'm more than certain that the problem is not in the router.
CPU: AMD FX 8320
GPU: GTX 970
RAM: 2x4Gb
OS: Windows 10
